The good news is I picked my car up from the shop today, it had a new clutch and flywheel installed. When I got it back i turned on the windshield defogger and noticed it was not defogging and the air was blowing directly to my face.
When ever I turn the knob that controls AC, MAX AC, vents, floor and defogger, all it does is blow from the top vents,
of the other settings work. The fan control works fine, the hot and cold climate knob works too. Worked fine before it went in the shop.
Also when the fan control is on high and you switch the climate from cold to hot, it moves by itself when you start to move it!
Wondering if anyone has ever experienced this, and if you have the cure
Thanks
of the other settings work. The fan control works fine, the hot and cold climate knob works too. Worked fine before it went in the shop. Also when the fan control is on high and you switch the climate from cold to hot, it moves by itself when you start to move it!
Thanks
