Topped my Z out tonight
  • Topped my Z out tonight
    I have always wondered what it would do, so i was goin 60 and stomped it and the next thing I knew 100...110.....120.....130.limiter. It may not seem like much but its plenty fast for me and I am amazed because the car is stock. (other than blowmasters)
    When did your limiter hit. I have had it around 153 and got scared. I'm sure it can go further. I once heard it was around 162 stock? It sounds wrong since I never got near it. The hypertech helps, but...
      Funny civic burn earlier. Have to give you props...
        It hit 130
          Do you know what RPM you were at?
          130 is the approximate top speed in 3rd gear. When my plugs were pretty shot, I tried to take it high, and it had a "fake" speed/rev limiter at about that speed because it would not get out of 3rd gear. The top speed should be between 150 and 160 if you were able to top it out in 4th.
            I Thought it was in 4th, mines an a4 but it could have been in 3rd for all I remember.
              With only the Spintech catback on my 97 TA, I was able to squeeze about 158 out of it. Takes a few miles to go from 145 to 158. We had the limiter deleted with a HPP3. The car felt pretty solid at those speeds.....just noisy. I just don't like the slight oversteer that our f-bodies have at those speeds.
                i have only had my 6spd up to 135, but the weather outside isnt the best for topo speed runs now. I was wondering what the limiter was but i only had mine for 1 month before it snowed And oversteer rules! Just not over 100mph haha
                '95 Trans Am 6spd- broke
                '77 dodge custom 150 2wd tire destroyer- 440ci w/edelbrock intake, thorley headers, 2000 stall, ported heads and surface rust
                2005 Kawasaki z1000 - getting too cold for that though
                  you guys are nuts......122 (at the track) is as fast as mine's gone....
                    The factory speed limiter setting is determined by the tires your car was equipped with when it left the factory. If your car came with the Z-rated tires (RPO QLC), the speed limit field in the PCM is entered as "255" (limit of 8-bit binary field). If it did not get the Z-rated tires, the limiter is set between 112-117mph, depending on the year of the car.
                      I've gotten mine up to over 150 but ran out of road. real fast! Big "highway ends in 1/4 mile, with a turn for that last 1/4! This was a year and a half ago. Everyonce in a while i'll get a bug in me and bring it to 130.
                      Traded in: 1998 Z28
                        how can you find out what kind of tires your car came with
                        My Car
                        Hooker 3" Catback Exhaust w/ gutted cat
                        1LE intake elbow, K&N Filter
                        Chris
                          140 over a railroad bridge caught some serious air lol never will screw around like that again.
                          -Lou -
                          1997 30th Anniversary Firebird Formula
                            I dont know what mine had from factory because I bought it used. Right now it has Michelin pilot Z-rated.
                              Not really sure on my 99 WS6. Never had too much oportunity to get it that high (tickets and worn tires). i go to fast-autos.net though and they have every fast car you can think of and there times. It said the 99 WS6 (anniversary) will go 160 mph. On a side note it appears the 05 GTO's will have more power than the F-bodies. (400 HP with 4.9 0-60)
                              99 Black WS6
                              99 Black Ski-Doo Mach Z
                              94 Jeep Grand Cherokee
