Anybody... I have a 94Z that keeps blowing the courtesy fuse 15amp. Sometimes it take up to 30min and sometimes right away. I have removed just about all the interior lights and even removed the radio. Any suggestions? Thanks...
Blowing Courtesy 15AMP Fuse
1blwnz28Tags: None
1blwnz28
What gets my attention is that sometimes it takes a while for the fuse to blow. If you had a direct short, it would pop the fuse immediatly. That leads me to believe that there is an intermittant short somewhere. I would advise getting a shop manual. It will have wiring diagrams that you can check every wire with a digital volt meter. When I get home from the office, I'll look up the diagrams I have and tell you all what exactly is in that circuit. At least you'll have a starting point. This is, unless Fred comes to the rescue and chimes in.....
1blwnz28 -
I had a similar problem with my '95 Z28. I had a wire in the console for the courtsey light pinched. Depending on how the console was jarred it would blow the fuse. It had me buffaloed for the longest time. This might not be your problem. Hopefully gives your an idea of what to look for.
John1995 Z28 A4/2.73 Black/Ttops, SLP cai, TB bypass, TB airfoil,
1LE elbow, HPP+, 160 thermo, Accel 300+ ignition box, Accel 9000 wires,
AC/Delco Rapidfires, LT4 knock module, TA shift knob, ???
1blwnz28
I will try a 20amp fuse. If that does not fix the problem I will go and get a chiltons manual. Let me know if you have any other ideas. Thanks for your help. The weird thing is that I just started one day. I really never drive that car its a 94 with 49000 miles on it. Its never seen rain or snow. I have 10,000 miles with the blower on it. It runs real strong... Thanks
1blwnz28
Well... I tried a 20amp fuse and it too snaped in about 5 min with the car off and no key in the ignition. No nothing in the car running... WOW what a pain in the @ss
cardoc
short
try your trunk lite somtimes it move's around. also you need to find out what else that fuse operate's beside's the courtisy lamp's and radio. I have alldata at my shop and if you give me a call on my cell i will look it up for you .
cell 321-794-2409
Don't think it runs anything else than the courtesy lights - I have some tropuble on my 98 with the light not turning off (probably the car alarm, as the door switches seem fine), so I removed the fuse - AFAIK only the lights are off now ...
Garry Glendown * '00 Firehawk M6 #92 * '98 Camaro V6 Convertible
This happened to me once when I owned my 88 Formula 350. I don't know if it is the same circuit on your car, but I figure I'd throw this out.
Check the cigarette lighter. Sounds dumb but, my formula had a freakin' penny stuck down in the bottom of it. Everytime you hit a bump or sometimes immediately it would short the lighter and blow the fuse. I overlooked this for a long time before I realized. If this isn't it, you will probably have to start probing wires.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
