Then I think I'll go with the Zexel-Torsen unit. I like having the traction through the corners. I'm assuming it still hooks up pretty well in a straightaway, right? Just not as good as the Eaton? Thanks for the advice on the spacer Aaron and Kev. Would it be a good idea then to just buy the parts and take it to a reputable shop? Labor shouldn't be too bad on that I don't think. But, is it possible to swap in a 8.5" 10-bolt off of a G-body?
Rear End Upgrade?
Steve
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
but with the 9" the entire carrier assembly can be removed at once.... that includes the carrier, pinion, ringes and center section. On a 12-bolt everything is intalled inside the housing and is not removable unless torn down......Originally posted by fastTAThe 12 bolt definitely takes less HP to turn. If you are experienced, doing a gear swap takes no more or less time to do with a 9" or 12 bolt. You still have to unbolt and slide the axles out to remove the centersection.
....... so with a 9" you can have 2 seprate carrier units, one low geared with a spool, the other high geared with a posi. you can change the assembly a hell of a lot quicker that you can install a new pinion and ring in a 12-bolt. Plus you woln't need a degree to make it run right.1967 VW Bug 2.3L Ford SVO Inline 4 w/ Turbo, Sand-Drag VW Trans Axle, Race this Import.
Yeah, get all the parts gathered up and take it to a "reputable" shop. I'd ask around and see if you can find a place that does a lot of rear work. As for the labor...just a guess...I'd say between 200-300 bucks. Someone correct me if I'm wrong.Originally posted by Steve93ZWould it be a good idea then to just buy the parts and take it to a reputable shop? Labor shouldn't be too bad on that I don't think.'95 White Z28 M6 Cold air intake with K&N air filter, air foil, flowmaster cat-back, eaton posi, motive 4.10s, aluminum driveshaft, "skip shift" eliminator, '97 Z28 chrome wheels, hypertech programmed
