Well it was bound to happen sometime. All i need to know is whether or not to buy the gasket or to just use a liquid seal or maybe both. If so which are the best to go with whether it be liquid sealant or gasket. Any help is greatly appreciated. Thanks guys.
Got the dreaded intake manifold leak...
Had mine fixed through the dealer just recently so I don't know what all the did and used but here are some previous threads that give you some answers.
http://www.f-body.com/forum/search.php?searchid=2332197 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
Buy GM intake gaskets and some Ultra Copper RTV. That is all you need to do. Worked fine for years for all the intakes I've helped do. No need to wrap pipes or anything. Just put a nice bead on the front and back of the block. Make sure the intake goes on nice and straight. And torque it down according to the book. After a couple of heat cycles, retorque it.
Then...enjoy a nice leak free intake
Rob
04 GTO
