Stock LS1 rear end strong?
  • Stock LS1 rear end strong?
    Will my stock rear handle drag radials? 99ls1 t/a
    I HAVE STOCK GEARS
    any ideas?
    1999 T/A M6 STOCK Slp Loudmouth , SKIPSHIFT ELIMINATOR, KNN FILTER SLP Short Throw Shifter w. slanted short stick, Ram PowerGrip Clutch C6Motorsport Rims w. 285/40 GoodYears
    CAR IS SOLD
    You better read this.
    http://www.f-body.com/forum/showthread.php?t=8728
      That's like the second time you've posted that, lol...
        To answer the question...
        ...if your motor is stock and you aren't making a whole lot of extra power, drag radials will probably shorten your rear end's life... but it'll hold up for a while.
          I just don't like for anyone to get into trouble or get pissed because their post disappeared.
            Depends to some extent whether you are running the A4 or M6 (you might want to include that info in your "signature"). The A4 generally subjects the rear to less shock. A 5K clutch dump on an M6 with drag radials or slicks might be more of a problem. The LS1 and LT1 rears are both the same weak 7.5/7.625" 10-bolt.
              I would suggest that if you plan on using anything but a regular radial, you add a rear differential girdle. It is a beefy cover that includes studs for the main caps as well as two preload studs to help keep the bearing caps from walking. As suggested, I wouldn't try high rpm clutch drops, but the girdle will help the differential live a little longer.
                He's an M6 - it's up by his name.
                  Sorry...... missed that.
                    my cars on its third rear....both broken before i got it, assuming on street tires.....
                    i rebuilt it and am taking passes on drag radials, no problems so far. we will see in the spring witht he stage 3 clutch though.
                    oh yeah, all i have done is headersback and a lid
                    pewter 99 TA...t-tops, leather, m6, lid, longtubes back, gears, spec clutch, spohn suspension
