n2o is not going to be used constantly, but running a 125 shot should I worry about setting back the timing at all?
nitrous timing question....
AMF RACING: Friends don't let friends drive junk
01 black ss #0966
lou's short stick, slp lid and cold air, smooth bellow, centerforce, loudmouth, 3 in. y pipe, flowtech long tubes, BMR STB, SLP 4.10's, polished zr-1s, MSD wires, T-6 plugs, and upcoming goodies....Tee-HeeTags: None
There are *rules* for retarding timing, but in reality your knock sensor will catch it. I run stock timing on my car and have never had a problem. Now if you get up to about 175 shot or so, you may want to start retarding it so the knock sensor doesn't have to do all the work."No, officer, that bottle is my onboard Halon system"
Make sure you use NGK TR-6's. I think they are supposed to be gapped at .035 for 125-150 shot. Also, don't forget WOT switch, FPSS, and Window switch, and bottle heater.1995 Firebird Formula
13.410 @ 102.66 11/20/05]
thanks all, yes I have already ordered the ngk t6's I ran n20 on a 97 z I had a while ago but only a 75 shot so I was curious, thanks
01 black ss #0966
I always thought for every 50 hp you takeout 2 degrees of timing to be safe. you shouldnt let the knock sensor do that for you it could be harmful to the engine by letting it knock before you take out timing but im no expert.99' TA 347 H/C MS4, QTP headers, 9' 4.11's
11.05@ 125 on motor, 9.80 @142 on nitrous
I know that *technically* you are supposed to take timing out, but particularly with the LT1 engine, the knock sensor is so sensitive it actually retards timing with false knock, so it can easily handle the requirements of a small shot of nitrous in that amount (100-125).
I know people that have an LT4 knock sensor on an LT1 car with nitrous and no timing taken out at all and have run them for a long time with no problems whatsoever."No, officer, that bottle is my onboard Halon system"
