Depends how far he plans to take the engine power-wise.... The MAC's are a 1-5/8" primary. Good for a "bolt-on" engine. But once you go to a good heads/cam setup, the 1-3/4" primaries in the AS&M's and most of the "long tube" header designs will support the engine better. The AS&M's are probably the best "non LT's" out there for the LT1, and I've seen a couple dyno tests where the AS&M's have outperformed LT's.
I've got 1k and these are my goals......
any idea where I can look at the AS&M's online?
13.685@102.11
There's an AS&M website:
AS&M
Pricey.... but I got mine "used" for $175
Check our sponsors for pricing and availability. A couple of reliable sources:
http://www.tbyrnemotorsports.com/
http://www.thunderracing.com/
AS&M's "on the engine":
How hard is it to get to the spark plugs with those?2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
WOW!!
1459.00 dollars for headers and a y pipe!? I don't think I want to spend this kind of cash.
I really only have 1k for this next group of mods.
I don't know how I am going to feel if I drop even 760 on just the headers right now...
am I an idiot for thinking this is a lot of money?
13.685@102.11
I'd go with CAI, gears, and as many suspension mods as you have money for... LCA, panhard rod, subframe connectors, STB, etc... Then when you get your next chunk of money, you can do heads, cam, headers/y-pipe, etc...
On a completely unrelated note, I've got SLP bolt on subframe coonectors for sale!
See my post in the for sale section
Dave M
The AS&M's are $750. They come with a Y-pipe that can be welded to your stock cat. The $1,459 setup is for the headers PLUS a complete new dual-cat Y-pipe, WITH the two cats. You don't need that. That's something you might consider in the future when you are up around 750HP.
RK Sport sells a "clone" of the AS&M's for less $$$Fred
Rk sport has listed a set of coated headers for 450. This price includes the y-pipe. They are listed as off-road only, does this mean that there is no place to plug in my 02 sensors?
Also they are 1 3/4 inch diameter. Is this the proper size I am looking for?
If this is in fact the proper headers, I would be able to do.....
CAI
3.73 gears
headers and y-pipe
How do you think this will help me at the track?
By the way, I am getting 11'' rear rims and tires, so I should have better grip than when I was running 14.30's all the time.
Thanks guys you are all very helpful as always.
13.685@102.11
In regards to installing headers on your driveway, Be prepared for the biggest headach, its a nightmare the first time because we all know the engineers who designed F-body's made it close to impossible to install headers and just about evrything else....Just Be PATIENT!!
......im not sure which of the two headers are a better bang for the $$$ but i can also suggest buying a real good set of gaskets for headers to avoid replacing a blown out gasket.
1995 CamaroZ28; A4(rebuilt vette specs w.2000stall),richmond3.73w.auburn rear, Eibach dragcoils w.airbag, alumn. driveshaft w.racing yokes, subframe/ control arms/ panhard, flowmaster/"loudmouth" y-pipe, Edelbrock headers shorties (nickelchrome of course), MSD ignition&coil, March pulleys, K&N CAI, Accel injectors & 255lph pump, LT4km, Garnatelli MAF, HPP w.160stat
A pair of Edlebrock headers w.nickelchrome worked well for me at about 425.00.........
Has anyone seen these intakes on e-bay?
http://cgi.ebay.com/ebaymotors/ws/eB...category=38634
Is this junk? I always heard that using aluminum was a bad idea because it would keep the heat in the intake tube due to the surface temperature of the metal.
13.685@102.11
Yup....that's pretty much junk. What's the point of a cold air intake when all you're doing is sucking in hot air from the engine bayOriginally posted by jerrystaHas anyone seen these intakes on e-bay?
A good CAI goes down alot further, and it has a metal plate just above the air filter. That metal plate blocks off the air filter from the engine bay and doesn't allow hot engine air to be sucked through your cold air intake
Anyone know what kind of power gains you'd get from just a CAI and cat-back? I keep seeing "Get 15 horsepower from our CAI", and that can't be possible. Can it?Red 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
SOLD- Good riddance!
I would imagine from a good cai you could see 10-15 hp, and maybe 15-20 from a good catback.Originally posted by NightrageAnyone know what kind of power gains you'd get from just a CAI and cat-back? I keep seeing "Get 15 horsepower from our CAI", and that can't be possible. Can it?
Factor in a drivetrain loss, and i would guess we would realistically see about
18-25 to the wheels.
I'm no expert though, that's pretty much the numbers that i have off the top of my head.black 95 t/a, a4, beefed up tranny w/ higher stall converter, transgo shift kit, trans temp gauge, trans cooler, richmond 3.73's, loudmouth, hypertech programmer, 160 thermo, descreened maf, TB bypass and airfoil, trick flow intake elbow, underdrive pulleys, moroso cai, edelbrock panhard rod, bmr stb, slp sfc's, fiberglass firehawk hood, hawk pads, taylor wires, ngk plugs, royal purple fluids,...and hopefully more to come
