I have a 94 formula and looking at sizes. Does a 285 fit without rubbing in the wheel well. and or what is the widest I can go with the stock wheel well.
Tire sizes
I have 285s on all 4 corners with 9.5 inch rims. It's never rubbed.
Many guys here have 315s in back. It's a tight fit and may require using a adjustable panhard bar along with some "massaging" of the inner fenders with a BFH.Tracy
I have 285's all around, the front rubs against the plastic fender liner a very little bit when the wheel is turned all the way, not enough to bother me or make me want 275s.2006 GTO Impulse Blue Metallic, Blue Leather Interior
Traded in: 1998 Z28
What size wheels are on it?Originally posted by rccola01I have a 94 formula and looking at sizes. Does a 285 fit without rubbing in the wheel well. and or what is the widest I can go with the stock wheel well.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
this is the key.Originally posted by Jeff 95 Z28What size wheels are on it?
The 285 on the back is fine, by why on earth would you want a 235 on a 9.5" wide wheel in the front. Most tire manufacturers do not even recommend a tire that narrow on a 9.5" wide wheel. You would have to go with a 235/50-17, to avoid going below the stock tire diameter, and that tire should not be put on a wheel any wider than 8.5", and preferably on a 7.5" wide wheel.Originally posted by rccola01Im putting 17x9.5 with 285 on the back and 235 on the front. Yokohama's
If you are trying to get a "skinnies" look in the front, you are going about it completely the wrong way.Fred
