I am going to install headers and dual exhaust on a 79 formula with a pontiac 400. Does anyone have any recommedations on headers and or exhaust?
header/exhaust recommendations
midget66Tags: None
Yea, whatever you get add the cost of a real big hammer and a pry bar. Putting headers on those old pontiacs is a bear because of the way the exhaust ports are angled on the heads.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
i think hooker headers are buy far the best "bang for the buck," but i would go with SLP exaust, or if you want to spend a little more money... get a borla exaust. Borla is pretty spendy though. I've heard bad things about the flowmaster exaust on f-bodies, so i don't know if it would be the best choice for your car or not.
1993 Formula - 99k
Throttle body bypass, K&N FIPK II, SLP Loudmouth, Mad Z28 Chip, 3.73 motives, TPI airfoil, Spohn LCA relocation brackets, Fuddle 3200 Stall, B&M Supercooler, LS1 driveshaft, and chrome ZR1's 17"/9.5" and 17/11" in the back!!!
good call
I am looking at Thorley or Dynomax for my '79. I am unsure, but I am still looking. I kinda want a ceramic-coated inner and outer finish. The Thorleys are nice for install, but they use a nickel-chrome finish. I am almost sure I am going with a dual Flowmaster 2 1/2 setup designed for the '70-3 model years, and then I plan to put high flow cats in off the headers. Here is a link to Summit's pic http://store.summitracing.com/partde...rt=FLO%2D17149 I was going to have it custom bent for my car, but then I found this one which was almost identical to how I wanted to set it up. If you plan to build up the motor past 450-500hp, go with 3 inch mandrel custom pipes out the back with a crossover just past the cats.. Ummm, don't be scarred off with the Flowmaster on this setup, and use true duals and dual Flowmaster mufflers as shown in the pick; you will be happy with the result. Don't be to anxious to set it up like one of the new gens.
I hope you have a hoist for this although you can use a good jack and bracing board for the oil pan. It involves taking the bolts out of the motor mounts, and lifting the motor to slide the headers in from under the car. There is also a little grinding involved
'77 K5 rock-crawler project
Thomas Jefferson
