swap my Auto trans with a 6-speed
  • swap my Auto trans with a 6-speed
    Has anyone out there ever swapped a Auto trans for a 6-speed on a LS1? Just asking for helpful advise. I have a 2001 SS and would like to be able to have just a little more fun with it.
    Hank Boonstra
    2001 Camaro SS Pewter
    LS1 HotCam, SLP Long tube headers, SLP "Loud Mouth" exhaust
    2000 Durango SLT Black
    2" Lift, 3" Pipes (from the manifold, back), brush guard
    I know that DJ Taso did the a4 to m6 but he has an LT1(pretty much the same thing, with a few differences) he should chime in and tell you whats involved.
    Sorry officer, im not speeding... Im qualifying
    Daily Driver:1990 ford probe 5 speed with like 13 horsepower at the crank.
      Check out this thread.
      http://www.f-body.com/forum/showthread.php?t=8848
      and
      http://www.f-body.com/forum/showthread.php?t=8977
      I've done it too.
        Be expected to pay over $3,000.00 for parts and labor if you're going to have it professionally done. The transmission alone will cost you $1,500.00 - $2,300.00 depending on where you get it. I got mine from a junkyard.
        My conversion kit cost me $1,750.00 with shipping. It came with pedals, console piece, master cylinder, transmission, shifter, knob, shift boot, etc etc. It also came with the flywheel but it had to be resurfaced. I didn't bother with it and got a new one instead because resurfaced flywheels tend to cause problems.
        I got my kit at www.lambertsalvage.com off a '97 Trans Am. You also need to get a wiring harness which is around $300.00, or your reverse lights wont engage.
        Also, stay away from Ebay since they only sell the cores, not the complete kit, but sometimes you'll get lucky and find a kit. If you get piece by piece its gonna get really pricey, its not worth it.
        This is what it cost me to get mine done:
        SPEC Stage II Clutch #SC422 - $479.99
        SPEC Billet Steel Flywheel #SC855 - $289.95
        Wiring Harness - $300.00
        Labor - $700.00
        Conversion Kit - $1,650.00
        Sales Tax (8.5%) - $160.98
        Total - $3,580.96
        I also purchased the SLP Stage 1 Suspension Kit for $816.95 which comes to a grand total of $4,397.91
        All work done by:
        Power House Performance Inc.
        15552 S. 70th Ct.
        Orland Park, IL 60462
        (708) 342-0043
        www.phpinc.biz
        __________________
        Also, N20LT4Bird converted his too. I'm sure he can help you as well.
        Hercules
        2008 Sunburst Metallic HHR LT
          When I converted from the T56 to the TH400, I sold my T56 as a conversion package. For $2,300 included:
          -McLeod Street Twin, steel flywheel
          -complete clutch hydraulics, modified for the Street Twin
          -bell housing
          -ballistic nylon bellhousing blanket
          -T56
          -Pro 5.0 shifter
          -skip shift eliminator.
          Was supposed to include swapping my pedals for his, but he never got around to doing the swap when I was already to finish up, so I just removed the clutch pedal and had a new tab welded on the brake pedal for a wider rubber cover. Excluded console, because I kept mine and put a B&M Pro-Ratchet in it.
            Wow it almost doesn't seem worth it. Hopefully I'll have some money saved up when I get back to the states. If so I'll probably go ahead and get it done. Thanks for all your help.
            Hank Boonstra
              Well I was in need of a transmission anyway so the difference wasn't that much.
