Hooked up hypertech programmer to correct speedometer, I also changed thermo.....went for a ride when done and everything is sealed up tight but the temp shoots up to where the check gauge light comes on.....at this point the car is not even warm enough to blow warm air through the vent.....so i delleted everything and started over again leaving everything stock cept the gears.....put the stock thermo back in and start'er up
this time I let the car idle in the drive way.....temp shoots up fans come on
still not hot enough to blow warm air through the vent......I let it idle for about 5 min, figured maybe the hypertech screwed up the temp guage....the check gauge light is on the temp says 260....car runs fine but then I notice the motor stutters in a revolutionthen powers back to normal then looses it again.......any idea what the hell is wrong???? everything is back to stock cept the gears
  The systems in these cars will always need to be bled due to the low height and location of the radiator.
