My oil pan drain bolt on my new Grand Prix was rounded off by the previous owner/shop. It's due for a change, so what is a good tool for removing a rounded off bolt? I think Sears' Craftsman makes a ratchet head for that, but I'm not sure. Anyone? I'll be replacing the plug once I get it out.
good devices for removing rounded off bolt?
Take a pair of vice grips, or good pliars. Put them on the nut. Take a pair of channel locks, put them on the pliar handle, squeeze the channel locks and turn. Should come right out. If room allows, this has worked for me every time with easy. Ran into this on my cat-back install and it took care of it, 10 seconds.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
the Gator Grip...use it for my "Really" rounded off oil pan bolt... Oh, not on the bird...on the company van.
Originally posted by Joe 1320Craftsman does make a socket with teeth on the inside for just such a purpose. As you tighten, the toothed threads cut into the rounded off bolt head, increasing the grip as you loosten the bolt.Steve
87 GN - its just a 6... Mods
