Tax's will be coming in within the next few weeks and im hoping to get enough back for Borla and a set of headers. i was thinking LT headers but where can i find something good at a good price.
header opinions?
Do you need to get it smogged?
I think the best smog legal headers are the SLP 1-3/4 coated shorties, which come with a y-pipe, and run $780 to $850.
Non-smog, and for somewhat stock internal motors, Arizona Speed and Marine are really good. They run about $750 for the set. They're mid-length headers. I think Fred said they did very well on a setup up to 700-800 hp. After then, a set of longtubes were able to produce more (don't remember which brand).94 Black T/A GT, Advanced Induction 355, 3200 stall, built 4L60E, Moser 9", Baer Brakes, Shooting for 11s...
Arizona Speed and Marine 1 3/4 Mid lenght headers. And if you get the Borla keep the cats cause it will sound better with it. They are the same price as the SLP's. I would also you check and see idf someone is selling a set. Bought mine used.
Kbddsfc,B&M Ripper,Ws6 Rims,Hotchkiss Stb,Bmr Lca,Gwphr,Strange 4:10's,LPEds,Borla,AS&M Headers,RT cat,Powerslot rotors,Hawk Pads R/Pf pads Fr,Mba shift knob,Slp Hood&Airbox,Holley Powershot filter,Fernco mod, Lt4km,Firebat decals,T/A Girdle,HPP.160stat,Bilstein shocks,Z06 Brakes,AFS ZR1's,GSD3's.
Your sig says you have hi-flow cats. I'd personally just pick up a set of pacesetter LT's definetly coated and have the the cats welded to the back of the headers then have a shop make you a y-pipe. If you don't need cats then you can just order the y-pipe from pacesetter for another $125. Its your decision but the LT's make more power and pacesetter will get nothing but great comments from me and I've read a lot of praise for them from other members. Also you can easily do that setup with coated headers for well under $600.1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
I can't find mid lenghts anywhere. I want LT's, but my car will be dropped 2" come spring. Where can I find MAC mids??Originally posted by Jeff95TAMAC midlengths with Jet Hot coating are reasonably priced and plug access is good!97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
buy something worth wild. go and get some Q T P's.they may cost alittle more than the rest but why spend money on stuff that not the best.plus thier stainless=last a lifetime.they have great ground clearance for your lowered car,install very easy, and all kinds of options w/ smog/air tubes/etc.they also make y pipes w/ all kinds of setups cats/no cats/dual cut outs.right now they are the best lt header on the market.a good set of headers will do you more justice than any catback!spend your money wisely!99' TA 347 H/C MS4, QTP headers, 9' 4.11's
11.05@ 125 on motor, 9.80 @142 on nitrous
I think he is talking about QTP headers for the LS1. I am pretty sure that QTP doesnt make headers for the LT1. But I could be wrong. AS&M and the 93-95 SLP headers have very good reps for being a great emissions header for keeping your cats.97 SS #C007
Polo Green w/ tan leather A4
You can get them directly from Jet Hot (if you want the coating that is).Originally posted by raroZ28I can't find mid lenghts anywhere. I want LT's, but my car will be dropped 2" come spring. Where can I find MAC mids??
1-800-432-3379 I believe Chris is the guy to talk to. They're around $600 with the coating.'95 Trans Am - A4, LE2 heads, LE1 cam, 1.6 ProMags, Comp R's, AS&M CAI, AS&M 54mm, MAC midlengths, Random Tech. cat, Borla cat back, PCMforless, Vigilante 2800, 3.73's, BMR LCAs/panhard/shock tower brace
I'll second this, Pacesetter Long Tubes are the best header for price in my opinion.Originally posted by 94 formulaYour sig says you have hi-flow cats. I'd personally just pick up a set of pacesetter LT's definetly coated and have the the cats welded to the back of the headers then have a shop make you a y-pipe. If you don't need cats then you can just order the y-pipe from pacesetter for another $125. Its your decision but the LT's make more power and pacesetter will get nothing but great comments from me and I've read a lot of praise for them from other members. Also you can easily do that setup with coated headers for well under $600.
