Originally posted by lt14mla
Wow, big motor!
na... it only spins at 102 RPMs. That's 1.7 revolutions per second. You could probably focus on one spot on the drive shaft and watch it turn.Tracy
you can count the spokes on the starter wheel from a Gasplant Compressor running at 300 RPM (50,000 HP est). I am lucky to have been an oil feild welder, I got to see alot of very big compressor engines. Biggest I aver saw was a 12 cyl. with piston bores big enough for two of me to stand in. It ran on natural gas. It was cool to watch run as it ran at 250-300 RPM and you could see the push rods and rockers as they were on the exterior of the engine
Eric W.
89 Firebird Formula WS6
Accel/Lingenfelter Super Ram
6.2L/382.97 ci
Custom PROM Dyno tuned
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
When the compressed fuel ignites, it must be like a decent sized bomb going offOriginally posted by smokeum99tabetter hope you dont have a back fire
SOLD- Kinda miss it
SOLD- Good riddance!
Originally posted by smokeum99tabetter hope you dont have a back fireActually, if it is like a normal size diesel engine. Fuel is injected after the piston has compressed the air. The fuel ignites and burns as it is being sprayed into the combustion chamber.Originally posted by NightrageWhen the compressed fuel ignites, it must be like a decent sized bomb going off
This says it's a two-stroke engine also. Trying to find more info on it...
edit:yup, same as a little one...marine diesel
Bruce, μολων λαβέ
CarfullyOriginally posted by Jay 02 TA ws6How exactly do you transport a 89 foot long, 300 ton crankshaft?
I'll bet you dont want to drop it. But seriously
Eric W.
6.2L/382.97 ci
WCT-5 speed
BW 9-bolt Posi 3.45
Boss MS 18" Rims
Custom Dual exhaust
1LE upgrade
That's nothing there's a dude over here in a Honda who says he has 2x the hp and can smoke it.
93 A4 Z-28: 383 all forged internals, CC306, Full Port & Pol. Heads 2.002 / 1.60, Comp-r Lift, Pro- Mag RR, 32# injectors, MDS 6AL, Adj. Fuel Reg., 160 Stat, Pcm-4-Less CPU, K&N CAI, 52mm TB, TB Bypass, 8.8 taylor wires, Shift kit, 3000 stall (built trans
), ASM LT's, Meizer WP, 3:73's, Eibach Pro Springs, Poly-graphite Bushings, KYB shocks, BMR LCA / Pan hrd & relocation brackets, Budnik 17x9's., 1LE sways & ALM. Drive Shaft. And on and on and.....
As sad as it is, even though that's blatently obviously sarcasm, there probably are ricers around that would think that. Just watched some of 2F2F tonight with my girlfriend. I can't believe that was passed off as a non-comedy.Originally posted by OverworkedThat's nothing there's a dude over here in a Honda who says he has 2x the hp and can smoke it.
You guys remember the ricers from that post about a week ago? The one's saying that domestic drivers are jealous of them because they can rev to 9,000 RPM's? lolRed 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
