can sombody explain how the rear turn signals are wired to flash on my 93 formula. as i am in the uk my car has had the turn signals converted to amber by cuting the center red section out of each lamp unit and a pice of orange acrilic put in and rewired so only that section flashes. i want to convert it back to red flashers and posibley use one of the secquncers so each bulb flashes in turn like the old thunderbirds and some mustangs. so i want to know how they are wired up. i would have thought that the wire coming from the turn signal switch goes to the earth of the lam units so when it is off and the lights are on the bulbs earth through the indactors but when you turn the switch on it cuts the earth and makes it flash and the same when the lights are off ie earth through the lights. i know it is a bit long winded but i can not explain it any other way sorry i hope you understand what i meen
