How Does Aion 2 Daevanion Work? Boards, Nodes & Crystal Guide
  • How Does Aion 2 Daevanion Work? Boards, Nodes & Crystal Guide
    Daevanion is a core system for character progression in the later stages of Aion 2. Resembling a grid-based board, this talent system allows for permanent stat boosts and the upgrading of active and passive skills - serving as a crucial mechanism for players to continue strengthening their characters after reaching the level cap.
    New players often find the complex web of nodes and the intricacies of resource acquisition daunting. This guide breaks down the Daevanion Boards, the effects of various node types, and strategies for obtaining and allocating Daevanion Crystals, helping you map out the most efficient progression path.
    Daevanion Boards
    Daevanion Boards unlock progressively as your character levels up. There are several distinct boards, each focusing on a specific area of ​​character enhancement.
    The Nezekan board unlocks at level 12, focusing on attack speed and casting speed to refine your combat rhythm. The Zikel board becomes available at level 20, emphasizing damage amplification and resistances - ideal for offensive builds. The Vaizel board unlocks at level 30, boosting critical damage and critical resistance. The Triniel board, available at level 40, enhances multi-hit capabilities and corresponding resistances. Finally, the Azphel board, which unlocks at level 45, is dedicated exclusively to PvP, providing stat bonuses that only take effect during player-versus-player combat.
    Each board is independent and requires its own investment of Daevanion points. You can prioritize which boards to unlock first based on whether you focus primarily on PvE dungeons or PvP fortress sieges.
    Node Types
    Each Daevanion Board is filled with nodes of various colors; the type of node determines its point cost and the benefits it provides. Gray nodes cost 1 point and grant basic stats such as HP, Attack, and Defense. Green nodes cost 2 points and increase the level of your passive skills. Blue nodes cost 3 points, enhancing your active offensive skills and directly impacting the effectiveness of your combat rotation. Orange nodes, located in the corners of the board, cost 4 points and provide percentage-based bonuses to your primary stats - serving as the ultimate reward for each board.
    Nodes must be unlocked sequentially, starting from the center of the board and moving outward; you cannot activate distant nodes directly. When planning your path, be careful to avoid wasting points on attributes that are irrelevant to your build.
    Daevanion Crystals
    Daevanion Crystals are the core material used to generate Daevanion Points; you must collect enough stals to exchange for these points in order to unlock nodes. Crystals can be obtained through main story quests, regional side quests, sealed dungeons, and achievement rewards - with higher-difficulty dungeons yielding a greater quantity of stals.
    However, the rate at which you can acquire stals is limited. Since fully maxing out every board requires a vast number of stals, it is not advisable to spread your points indiscriminately across all available boards. Farming dungeons for stals consumes significant amounts of potions and requires frequent gear repairs; furthermore, buying crafting materials from the Auction House necessitates a steady supply of Aion 2 Kinah. Maintaining a sufficient Kinah reserve ensures efficient, long-term stal farming without disrupting your character progression.
    Notes
    As your character development progresses, you will find that - beyond the Daevanion system - enhancing gear, socketing manastones, and crafting godstones all require a continuous expenditure of Kinah. If you prefer to avoid spending excessive time repeatedly grinding dungeons, buying Aion 2 Kinah allows you to quickly stock up on essential consumables and crafting materials. This lets you focus your efforts on farming Daevanion Crystals and efficiently unlocking nodes on your boards.
    Many players choose to develop multiple character classes simultaneously. Since each class follows a unique Daevanion progression path, managing multiple characters leads to a higher demand for stals, gear, and materials. Having a reserve of Aion 2 Kinah on hand makes it much easier to support the Daevanion progression for several characters, allowing you to quickly experience the full potential of different class builds.
    In short, the Daevanion system is central to endgame progression in Aion 2. Its Boards and Nodes framework offers a high degree of flexibility, and the specific path you choose to invest your points in will directly determine your character's power. Plan your progression order carefully and allocate your Daevanion Crystals strategically - avoid the temptation to max out every single node. By pairing this with a solid supply of Aion 2 Kina to ensure a steady flow of dungeon supplies, you can reach your character's endgame-ready state much faster.
