Just what I needed, went to start the car this AM and no fuel. The pump is dead. Just how I wanted to spend a Saturday, on my back in the driveway. At least the whole rear suspension has been upgraded so the bolts won't be frozen and on the mufflex I used stainless band clamps so everything should come apart easily. The other fortunate thing is there is less than half a tank of fuel. I'm still not looking foreward to doing the R&R.
Barf..... fuel pump is DOA
That's worse than my problem. Wednesday my clutch pedal took a dump. I thought you were supposed to dump the pedal. Something is wrong with the hydraulics.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Originally posted by FroSStyOh you know you want to cut a hole in your rear floor....
Be careful with the walbro pumps, if that's what you're getting. I replaced mine with a walbro and it died the next day. Took it back and got a new one, and it's been fine since. Be a shame if you went through the same thing after dropping the rear suspension. I was thanking god I cut a hole when that happened.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Sorry to hear 'bout it. I do have to ask, I haven't yet had to replace the fuel pump in my T/A, what is all involved? Sounds like I'm not going to like it But with my baby having 109K, I bet I'm gonna have to replace it soon.1996 White T/A, LT-1 auto with only aftermarket Flowmasters, shift kit, and a LG Motorsports G2 cold air kit.....that's it! She can't eat all the 'Stangs but will die trying.
Currently on the clock: 120K
Originally posted by 'STANGETRSorry to hear 'bout it. I do have to ask, I haven't yet had to replace the fuel pump in my T/A, what is all involved? Sounds like I'm not going to like it But with my baby having 109K, I bet I'm gonna have to replace it soon.
Or you can drop the rear suspension, drain the tank and drop that as well. Then pull the pump, replace, and put everything back together.
If I had the space and time I'd do it Joe's way, but I had to get to work the next morning. No garage either, so I cut it up in front of my house and popped a new pump in.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Originally posted by raroZ28Piece of cake if you cut a hole in the trunk. Takes literally 15 minutes.
**This is my personal opinion only. Im not an expert in car structures by any stretch of the imagination, and I didn't stay at a Holiday Inn Express last night...**
I have severe reservations about cutting a hole in the body, above the rear axle, of a unibody car. The majority of the pictures I've seen of these holes, shows people have cut them with square corners (a round or oval hole is better). They also haven't reinforced the opening before sealing it back up. This, to me, is just asking for stress cracks from the flexing of the body at the opening. I'm sure a hole could be made that I would be comfortable with, but it would take more than a few minutes work to do.
Bruce, μολων λαβέ
Originally posted by bru333When did you cut the hole? I'd sure like to see photos of a hole that has 20/30000 (or more) miles on it...I've seen lots of photos of holes when people have cut them, but later after a year or two of driving.
I have severe reservations about cutting a hole in the body, above the rear axle, of a unibody car. The majority of the pictures I've seen of these holes, shows people have cut them with square corners (a round or oval hole is better). They also haven't reinforced the opening before sealing it back up. This, to me, is just asking for stress cracks from the flexing of the body at the opening. I'm sure a hole could be made that I would be comfortable with, but it would take more than a few minutes work to do.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
Originally posted by raroZ28A lot of cars come with those holes already there.
Every car should have this for easy pump R&R.
I could snap some pics.
Bruce, μολων λαβέ
Originally posted by bru333How many miles since you cut the hole?97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
went and snapped a pic really quick. You can't really tell much, I wrapped the steel in this as a barrier between the cars sheet metal, and the sheet metal i screwed to it. I didn't want it to ever rattle.
You can't see much. BTW, yes, I used the stuff that you put to line your toolbox.
Originally posted by Joe 1320It is alive, and I'm spent.
Moron factory engineers should be shot.1996 White T/A, LT-1 auto with only aftermarket Flowmasters, shift kit, and a LG Motorsports G2 cold air kit.....that's it! She can't eat all the 'Stangs but will die trying.
