http://www.water4gas.com/2books.htm, everone at my work is talking about doing this to there car,I think its a load of crap,I wanted to get ur guys thoughts thanks
water4gas
 water4gas2000 blue mustang gt vert 5spd,18''cobra rims,light bar,stalker bodykit,lowered 2 1/2'',roush side exhaust /with x pipe ,bbk cai,power products 75mm tb and plenum Pro 5.0 3:90 gears,Custom 91 octane SCT tune
 2000 red vw jetta,86k stock
 1995 firebird formula ws6 clone,crashed,frame damage ,sold Tags: None Tags: None
 and it is a load of cr@p.
 The theory is valid but the practical application...no way.
 Decomposition of water into hydrogen gas and oxygen gas by high voltage electric discharge.
 2 H2O + High Voltage Discharge => 2 H2 + O2.
 In fact we have multiple H2 generators in our laboratory. They run about $10k each, 120V AC, are about 20" X 18" X 12" and produce around 100ml/min H2 at 60 psi. Oh, and did I mention the palladium catalyst that is needed to assist the reaction.
 Problems:
 It lakes ALOT of current to break the H-O bonds.
 So much so that it is not even remotely efficient but it is safer than using compressed H2 cylinders which is why we use them.
 Plus, there's the simple math.
 1 H2O molecule weighs 18.015 amu (amu=Atomic Mass Units)
 H weighs 1.008 X 2 = 2.016 which is 11.19% of the total.
 Meaning, if your conversion is 100% efficient, you only get 11.19% return.
 And the lower BTU value of H2 versus hydrocarbons....
 Then there is the whole problem of delivering a gas into your engine to consider...
 Get the picture?     My DD My DD
 2015 Lexus GS350 FSport
 My toy
 I didn't believe it either until a friend of mine said he was using it with great results.
 I figured I'd try it and I've about doubled my gas mileage and have had no noticeable loss in power.   97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM 97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
 Woops, forgot to say happy late april fools.Originally posted by Joe 1320Now I'm worried.
 I wonder if anybody has really bought that though.97 Chevy 'Raro Z28 M6- Ported & Polished LT1 heads,beehives,1.6/1.94 valves, 226/231 custom cam,K&N FIPK, 94-95 BBK shorty's,ORY,Magnaflow Catback,no cats,BMR LCA Relocation Brackets,Lower Control Arms,Adjustable Panhard Bar,Eibach Pro Kit,SPEC Stage 1,Walbro 255 Fuel Pump,30LB Injectors,Pro 5.0,Short stick,MSD 8.5's,NGK TR55's,LT4KM
 thats ok, im still trying to figure out how to turn used tires into wine! I'll make a fortune!
 Ahhh say there Mr. Joe, care to sip a vintage goodrich g force 1997?
 Originally posted by wolfdogsthats ok, im still trying to figure out how to turn used tires into wine! I'll make a fortune!
 I'm doing something similar with black licorice.... except i am calling them Pirelli's Fine Licorice. -Ryan- -Ryan-
 Originally posted by raroZ28
 Those are actually commercially available right now. $7000
 http://www.alternatefuels.com/h2o1.htmTracy
 If it really worked you'd be seeing cars with the technology already build in. I can promise all the major car makers are spending billions to make a more energy efficient car, even more so now than ever. But some gomer with a cheesy website beat them all to the "real" answer to energy independence? Right, when pigs fly.Tracy, 97 Formula, pretty much stock.
