After over a month of nail biting and various problems, I finally got the title to the 93 Z that I purchased last month. I wasn't going to really dig into the car until I had the title in hand. Now that I do, let the games begin. I already swapped the wheels and tires for the 2002 chrome 17" SS wheels and 285/40s, next is to replace the worn out rear control arms with the good stockers that were pulled from the T/A long ago, then I have to tackle the oil leaks. The intake manifold leak should be pretty easy having done it a few times before, the rear main seal is going to stink. I hate pulling a transmission all the way down to the crank. There is also a cooling system leak, it appears to be the water pump gasket as the weep hole is dry. Other than those problems, there are only a few small items that don't affect the mechanical integrity..... the majority are simply appearance issues that will require a little TLC. The really impressive thing about this car is that nothing is missing. All parts appear as original and there are no speed parts or modifications of any kind...... a bone stock car (140K miles) with a new transmission and clutch, 2.73 rear, power locks, windows, cold a/c and a hardtop. It has had some paint work along with an area that the repair isn't too swift, so I'll have to dig that out and fix it right. The reminder of the car should be a nice 5 footer. You savy car guys will know what a 5 footer is....... the paint will look really good from 5+ feet away, any closer and the blemishes begin to show. Ultimately I want to keep it relatively stock, but I want to add an SS hood and the center mount exhaust from the 2002 SS. Those will be the last items added as so many other more pressing items are the priority. All of the initial test drives show this to be a stong runner with just some minor issues. I'm going to use this as a daily driver/highway cruiser and post all the resoration processes for folks to follow along if interested........
The idea with this car will be to show how it's possible to purchase a nice higher mileage f-body, do a basic home resoration of a daily driver along with fixing the issues that the previous owner simply couldn't keep up with, and end up with a good looking and solid cruiser/bruiser without breaking the bank account.
That means no high dollar wheels and tires, brand new Corsa cat backs, superchargers.... and folks get the idea. I'm going to replace defective stock parts with stock parts and put the car in as close to as new condition as possible with as little cash outlay as possible. Now once that level has been achieved, then some mods may be done with the low budget principles applied.
I think they must have used not high temp clear and the oil turned it tan. I was definately leaking. In any case, the main gaskets were fine, I redid the silicone using high temp black and layed a nice thick bead. It is setting up as I type. I should have it done by dinner. I found a few vacuum hoses that were cracked..... I'll need to search for the part numbers as these are molded elbows. Why people can't do the job right is beyond me. It's not that hard.
