It's good to see that you appreciate everything that is being done here for you, but if you arent going to post about the same problems all the time then you can't be taking the advice given to you very seriously, or you wouldnt be getting the same responses. Perhaps if you tried their ideas and then posted their effectiveness it would work out. It's good that you learned from your mistakes but don't get the wrong idea about these guys, they only want you to get the best advice possible so you can get your car up adn running properly.
Dyno tune Saturday
jessica2112
Thank you, your right. I I do owe them alot. I just lose track of all the information, and repeat myself. I must be going loony. I'll just search them all and copy the replies. I do try what they tell me, but I only have Saturdays to do most of the stuff. I just rented a garage too, so now I can work on it here too. I cant use my friends shop all the time
I didn't post it, I made reference to it because it was relevant to the situation. I wasn't going to let you take your football and go home because of misperception.Originally posted by jessica2112Whats the use of a private message if you post it?
A relative new tuner that is likely on par with a hypertech power programmer. Those have limited ability to modify certain parameters that have nothing to do with actual engine tuning. More like fan turn on and off points, transmission shift points, etc. Some of the GM V6 codes are farther along..... GTPs and similar with the factory blown 3.8 are obviously farther along than the f-bodies due to the mass production of those vehicles and there are some companys that can offer some tuning. For what it's worth, there are many people standing in lineOriginally posted by jessica2112So, if the GM V6 code is not cracked what is HPtuners?
to get those tuners as demand exceeds production.
We won't even go there as it has no bearing on the situation.Originally posted by jessica2112I guess you all have never made a mistake with your first hotrod.
It should be, too bad that many people don't. That is one reason why most of us try to help others from making the same mistakes we once did.Originally posted by jessica2112I learned from my mistakes. Is that not human nature?
I still stand by my statement that unless a shop is using a wideband 02 sensor and can modify every single parameter that exists, they aren't doing an acceptable dyno tune. For what it's worth, I probably have more experience with tuning a V6 than most on this board. My GN is based on the same basic configuration as the latter 3800s and it is in the 10s at 130 mph in the quarter. I've been experimenting since 92, and have done 100% of the work and tuning so I am confident in my analysis of the situation.
jessica2112
Thank you for the information and clearing some things up. I was misinformed on the capabilities of the HPtuners. I had planned on not going, or if I did, maybe just do some pulls, just to see where I stand.
You at least need a wideband fitting before the cat - they should be able to do it for you there, but if not, you will need to have it done before you go - I realize there's not any time for that... An O2 sensor probe up the tailpipe won't work with a cat before it. It would be good to know your a/f ratio, or else i don't know what all they're going to be able to do for you other than tell you what power you're putting to the wheels. Shame you don't have the exhaust sorted out yet. Anyway, good luck, and let us know how it goes.
jessica2112 -
hmmmm
the ice is thinning
before you go and rule out the dyno tune altogether, make sure you talk to the shop and understand exactly what they'll be doing for you. If they resist or can't seem to tell you like they have been, then I'd try to find someone else, even if it means having to wait until you've saved a little more money.Dave M
