Originally posted by 95z28
Got a new Cobalt SS
"beefy internals" help, but the static compression is still 9.5:1, and that is high for a boosted motor. All that the beefy internals do is make the motor stand up to pre-detonation better, it doesn't reduce the occurrence of it... which is why you would want to lower the compression ratio.Former Ride: 2002 Pontiac Trans Am WS6 - 345 rwhp, 360 rwtq... stock internally.
Originally posted by Joe 1320It's not all about boost. If you are trying to cram 12 psi through a small 1" pipe, you'll get small power. Push 12psi though a 3" intake pipe, you'll get much more power. It's all about total airflow, not just pressure.
The car will respond nicely to typical performance mods that eliminate restriction and pumping losses. A free flowing exhaust and intake should do wonders.
yes, most people forget this. You an can make more power on a free'er flowing motor with less boost than a lesser flowing motor on more boost. IVe seen the airbox on those cobalts and it looks pretty restricitve. Thats probably a good place to start.
But they look like fun!96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
