That's a good thought...I'll check on it. However, I think I know what the problem is.
It's most likely #7 that's leaking. That's because when a bolt originally snapped there, I had to drill out and heli-coil that bolt hole. Well, it turns out that the heli-coil might have adjusted some (from constant tightening, untightening), meaning it might be sticking out a tiny bit. So this may be preventing the gasket from seating properly on the head. I'm going to once again remove the header and try to cut off the excess coil sticking out. I'm almost certain that's the problem...but wasn't the problem previously because it was seated fine.
I also closed the cutout and plugged up the left tip with shop towels and saw exhaust coming from the back area of the header. So it's either that, or the EGR as you mentioned.
for the RTV to cure, then will see from there. Otherwise, I have to take the header back and tell them that the "cuts" or "holes" are leaking.
And like I said before, RTV obviously doesn't belong anywhere near the exhaust of a car that relies on O2 sensors to adjust a/f ratio. Even the supposed "sensor safe" RTV contains small amounts of silicone.
