My 2000 Camaro's rear has recently started to squeak when going over speed bumps, rough roads, etc. Is it time to replace the rear shocks? I currently have 72,000 miles on the original ones. Or could it be spring noise which I assume there isn't a cure to? Thanks for your replies in advance.
Rear Suspension Noise
Make sure its not the rear hatch first. Mine was squeaking going over bumps etc yesterday and it ended up just being some ice in the gap between the hatch and the roof.Red 1996 Firebird
3800 V6, T-5
Alpine CDA-9835
Kicker S8L5 in a Bassworx SQ8
Rockford Fosgate P3001 rated @ 391w RMS, 1194w Max
Also check the sway bar end-links. My Z sounded like an old man groaning every time I went over a bump. Not any more
Mods
87 GN - its just a 6...
Mods
93 Z28 - slightly tweaked
Mods
hahaha......Originally posted by 97LT1Z28That happened to me too. I popped the hatch, and it WAS an old man groaning - I told him to get lost . . . . . .
-Dan
I'm gonna guess it's your rear hatch shocks. Every camaro does that. Mine squeak if you run over a bug, so it is pretty much a constant squeak. Turn up the radio and it drowns it out.
That's an awful thing to do to your dadOriginally posted by 97LT1Z28That happened to me too. I popped the hatch, and it WAS an old man groaning - I told him to get lost . . . . . .
lol j/k
Mods
Mods
Mods
wtf? Wolfman tried sneaking into your hatch too?Originally posted by 97LT1Z28That happened to me too. I popped the hatch, and it WAS an old man groaning - I told him to get lost . . . . . .
Update
Well I never did find what the noise was until it got really annoying and louder as well. It sounded like my rear end was about to fall off. Anyway, it ended up being the control arms. Both sets of bushings were extremely worn out. I replaced them with aftermarket ones made of polyurethane to last longer. What a difference it made. The rear end is solid again.1988 5.0 TBI Camaro 700R4 Transmission
holy thread back from the dead!!!
If you're interested in controlling your VIZIO TV with a smartphone, vizio.com/setup provides a useful starting point for initial configuration. Complete the TV setup first, then use the VIZIO Mobile app to search for compatible devices and follow the displayed pairing instructions.
vizio.com/setup can support a smoother transition from basic TV installation to connected mobile features. After establishing your television's internet connection, use the VIZIO Mobile app if supported by your model. Follow the pairing process and enter any code displayed on the television when prompted.
Users exploring vizio.com/setup can learn how initial TV configuration connects with mobile functionality. A compatible VIZIO television can work with the VIZIO Mobile application for device control. Ensure both devices are connected properly and follow the official app instructions to complete pairing.
Vizio.com/setup can help customers prepare their VIZIO TV for modern connected entertainment. After completing initial configuration, users can explore mobile controls, casting, and supported applications. Follow the VIZIO Mobile pairing instructions and make sure your phone and television are connected to the same network.
For users interested in casting content,Vizio.com/setup can help establish the necessary TV configuration. Connect your VIZIO television to the internet and ensure your compatible mobile device uses the same network. Once setup is complete, supported casting features can be explored through compatible applications.
