Originally posted by 88bird5spd
list all power drians here
actually an elect hatch pull down would start up when i close the driver door right? well next to the rear driver side seat in the wall there is a motor sound some times , but it quites, schematics show nothing is there!1982 Trans am w/ t-tops
previous owners abused it!!!
that dont sound right, but u have a electric hatch pull down? make sure its fully close and turns off completely when the hatch is closed. they are known to cause battery drainsOriginally posted by Maverick_82actually an elect hatch pull down would start up when i close the driver door right? well next to the rear driver side seat in the wall there is a motor sound some times , but it quites, schematics show nothing is there!2009 Honda Civic EX- the daily beater
i dont always use my back hatch and the motor sound does stop after a few seconds. also, i dont believe the 82 trans am had an electric pulldown!?! another thing, sometimes my radio will jump frequencies!?! its a few years old, a panasonic cd/radio, pre-mp3 car radio. the station changes, i think due to rpm variations. not all the time due more so recently. id say a major short. could it be the cause of the battery drain? however, there was a battery drain before i installed, when the previous owner had it. i removed his jensen car tuner before i ever noticed any problems.1982 Trans am w/ t-tops
mybe the battery wont hold a charge over time, mybe see which fuses have current flowing through them when off.2000 trans am auto, Afr 205,tr 220/220 112, mti lid, 160t,umi sfc,hooker headers and ory y,loud mouth. bellow,pr's,harland rockers,new lifters,ls6 oilpump,rollermaster doubler roller, msd wires.
My suggestion is checking for an active drain at the fuse box. One by one, pull all the fuses and see what circuit is the culprit. I had this same frustrating situation on my 94. I eventually found an old aftermarket alarm system hidden under that dash that was draining power even though it wasn't turned on. Ripped that sucker out and no problems since.
when the key is on, my cars courtesy lights draw 11.86 and when the key was off and all doors where shut, the fuse socket still had 6.26 running through it.Originally posted by Joe 1320My suggestion is checking for an active drain at the fuse box. One by one, pull all the fuses and see what circuit is the culprit. I had this same frustrating situation on my 94. I eventually found an old aftermarket alarm system hidden under that dash that was draining power even though it wasn't turned on. Ripped that sucker out and no problems since.1982 Trans am w/ t-tops
there is not a single drain found when i checked the fuse box.
