Originally posted by WhiteSmoke
Next MoD?
Don't worry about getting a bigger TB than the 48mm stocker for now. The stock 48mm flows more than enough for bolt-ons. Have you done the TB bypass yet? Maybe some LCA's or SFC's. The 10 bolt girdle is also a good investment IMO.
no i havent done the TB bypass never really looked into that and not sure what LCA SFC is, sorry for the dumbness..=/ im just getting started learning up on the LT1's95 Z28 LT1, Edelbrock headers w/ Full exhaust, cold air intake, TCI 1800 stall convertor, shift kit, Eibach springs, KYB shocks
No problem.Originally posted by WhiteSmokeno i havent done the TB bypass never really looked into that and not sure what LCA SFC is, sorry for the dumbness..=/ im just getting started learning up on the LT1's
LCA stands for lower control arm. SFC is sub-frame connector.
Check out www.ws6.com for some basic mods to the LT1 and their respective dyno gains.
Here is a list of commonly used acronyms to help out:
http://www.ls1tech.com/acronyms.html
You have had a good attitude every since you signed up here.Originally posted by WhiteSmokeThanks for your patience =)
That goes along way in my book.
thanks guys =) means alot, im s trong beleiver in what goes around comes around =) u guys are great glad i joined...i've learned more in these past few days about my car than i have, hanging out with my oldschool hotrod buddies in years, there not into the newer cars like us =P95 Z28 LT1, Edelbrock headers w/ Full exhaust, cold air intake, TCI 1800 stall convertor, shift kit, Eibach springs, KYB shocks
Man, that's your solution to everythingOriginally posted by fastTA150 shot!
SOLD- Kinda miss it
SOLD- Good riddance!
You know, I used to be really against the use of nitrous. I guess I have become more open minded as I gracefully age!Originally posted by NightrageMan, that's your solution to everything
The way I figure it......it's the best bang for your buck mod available. Can't go wrong with that.
For a baby 50 shot, no tuning is necessary, if anything the overly rich PE mode is just extra padding. Some people feel safer going to a half heat range colder plug and pulling 2 deg of total timing, but it is definitely not a requirement.
A healthy LT1 motor will easily handle a 100-125 shot. LOTS have run a 150 shot with no ill effects.
