Originally posted by Nightrage
My tranny is grinding
About the same as a new stock clutch. It will be fine.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Well, according to my mechanic, the clutch does need to be replaced, however that isn't what's causing the grinding. It only happens when the car is warmed up. I've been reading that our tranny synchros require friction to work properly. I'm running Royal Purple in the tranny
I'd imagine that's what the grinding is. Next week he's going to swap the new clutch in and replace the tranny fluid with factory recommended stuff. I'm a little disappointed. I can shift my car with my index finger due to how smooth it is right now. I'd imagine it's going to be notchy again when I switch back. Oh well, it's a small price to pay, I suppose
SOLD- Kinda miss it
SOLD- Good riddance!
I run Royal Purple Synchromax in mine with no problems.Dave
Independent AMSOIL Dealer
94 Z28 M6 - exhaust, K&N drop in, and lots of plans...
DD 98 Ram 2500 CTD (might be faster than my Z!)
It's fixed, but now I'm confused
I got my car back. I had the clutch and fuel filter replaced, plus my oil pressure switch was replaced (my oil pressure is much higher now). For some reason, the clutch now releases an inch from the floor whereas it used to release an inch from the top. The mechanic said this is normal because it's a hydraulic clutch. He told me that as the clutch wears out, the pedal starts to engage higher and higher. I suppose that makes sense, but both the truck I drive at work (F-150 with a relatively new clutch) and my dad's Viper release very high up. If the clutch moves up over time, why do those clutches release right where mine did, even though they're not worn?
For anyone wondering, the pedal feels the same as it did with the stock clutch, there's no chatter and it holds extremely well. It's a little expensive, but so far I think it was a good investment.
A few more questions for anyone who feels like answering them.
1. A few months back I had my car dyno'd. That was with the slipping clutch. Would I pull higher numbers now with the new one?
2. My car sits at about 1400RPM at 60MPH now. It used to sit at about 1700RPM at the same speed with the old clutch. Is that normal? I guess my old clutch must have been slipping pretty badly in order for that to happen?Red 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
Did they break the old one? Remember my hints above.Originally posted by Nightrageplus my oil pressure switch was replaced (my oil pressure is much higher now).
It should be about half way. If it is too close to the floor the hydraulic system is pushing on the fork far enough for it to release the clutch. That could be a sign of it having air in the system. When you put the system back together after changing a clutch it will usually have too much fluid in it You might want to check the level. Also the clutch fluid is not the same as Dextron ATF fluid or brake fluid. GM calls for a different fluid. I made the mistake of putting the wrong stuff in mine and it made the clutch point too low.Originally posted by NightrageFor some reason, the clutch now releases an inch from the floor whereas it used to release an inch from the top.
That is true of a cable clutch not a hydraulic clutch. A hydraulic clutch will keep the same release position over the life of the clutch until it wears out and runs out of travel.Originally posted by NightrageHe told me that as the clutch wears out, the pedal starts to engage higher and higher.
I would think so.Originally posted by Nightrage1. A few months back I had my car dyno'd. That was with the slipping clutch. Would I pull higher numbers now with the new one?
I guess if it is really worn out. I wouldn't worry about that because it is better now than before.Originally posted by Nightrage2. My car sits at about 1400RPM at 60MPH now. It used to sit at about 1700RPM at the same speed with the old clutch. Is that normal? I guess my old clutch must have been slipping pretty badly in order for that to happen?
I bet your gas mileage will be better now.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
Thanks Jeff!
I would imagine he broke the sending unit, but since it's been replaced I've had much better oil pressure.
Is that detrimental to the car? I actually like where it releases now. The car had been releasing at the top since I bought it with around 58K miles on it. Could the clutch really have been bad for that long? Anyway, it's consistant now whereas I used to rev the motor a bit before it grabbed in the right spot.Originally posted by Jeff_in_AtlIt should be about half way. If it is too close to the floor the hydraulic system is pushing on the fork far enough for it to release the clutch. That could be a sign of it having air in the system. When you put the system back together after changing a clutch it will usually have too much fluid in it You might want to check the level. Also the clutch fluid is not the same as Dextron ATF fluid or brake fluid. GM calls for a different fluid. I made the mistake of putting the wrong stuff in mine and it made the clutch point too low.Red 95 Trans Am: M6, Moroso CAI, Magnaflow, Spohn sway bars, back to life as of 2/15/10!!!
SOLD- Kinda miss it
As long as you are not grinding gears it's fine.Originally posted by NightrageThanks Jeff!
Oh your oil pressure isn't any different than it was before. The gauge is just reading higher with the new sending unit.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
