It wasnt that bad. LS1's are a bit easier than a LT1. Driverside 15 min. Passenger 45 min taking breaks. #8 PITA , just did from beneath. All in told 3 scrapes , no bruises. and new TR55's
I took on a sparkplug change
Pacesetter longtubes on mine make it a really dumbass job to do.
The passenger front is the hardest on mine id say from the bottom, impossible from the top.
Wouldn't it just be great if the plugs were in the TOP of the heads like a honda....
-Alex
ZO6 wheels (clones)
With questionable guts:
Forged bottom end
pacesetter longtubes
K&N RAM air from 96 ws6
96? ws6 hood
96? ws6 spoiler
full emissions delete
Edelbrock IAS shocks
a swivel headed 3/8 ratchet helps, also twist both ends of the wire before trying to pull off, and if the person before you used dielectric grease inside both ends you should thank them2002 Firehawk, LS 7 Flyw/clutch,
Kooks Hdrs/Y high flow cats, SLP Ldmth 1 catback,
Spohn solid motor mounts/lowr panhard/tunnel brace
BMR Billet control arms/upper panhard/tourque arm/trans crossmember
Eibach springs/sway bars
My swivel head sucks, it has a mind of its own, and with a heavy plug socket on it, its such a pain getting it where it needs to go. I find it easiest to use a box end on the back of the spark socket, best thing for me getting past the headers.-Alex
ZO6 wheels (clones)
Forged bottom end
96? ws6 hood
96? ws6 spoiler
