jump the real basically ground it ur self i can tell u how to do it in a w-body i dunno if its the same for a f-body but its basically easy n u can run it off of ur own switch pretty neet if u ask me
manual fan switch
hazmat -
thats what yourdoind i think. you wire into the wires instead of the actual relay. you manualy activate teh relay and thats what causes a ses light. the resistors stop the cup from sencing that the fans are on....or i could be talking out of my @$$ ^.^ i just thought of that weather its trueor not i dont know but it sounded like i knew what i was talking about huh?
1997 Camaro, Z-28, 5.7, Manual 6, K&N cold air intake, custom ram air scoop, ported MAF, Resonator plug, air foil, 160 thermostat, hypertech power programer 3, 3 inch cat-back exhaust, strut tower brace, K&N valve breather, centerforce dual friction clutch, slp short throw shifter, TNL short stick, O2 simulators, Next mod will be 1.6 rockers, pushrods, and springs. any reccomendations?
also to reply to WHY? well ive read that if you keep yourengine cooler it wil prevent detonation and its always good to have a cooler runing engine and it prolongs thelife. my car now is running between 160 and the first hash mark! and its agood 30 min stop and go drive! i stillhave as muchposer as if the engine was just started. plus when i poped my hood i was not bombarded by heat. i really recommend this for anyone in stop and go. it really helps!!1997 Camaro, Z-28, 5.7, Manual 6, K&N cold air intake, custom ram air scoop, ported MAF, Resonator plug, air foil, 160 thermostat, hypertech power programer 3, 3 inch cat-back exhaust, strut tower brace, K&N valve breather, centerforce dual friction clutch, slp short throw shifter, TNL short stick, O2 simulators, Next mod will be 1.6 rockers, pushrods, and springs. any reccomendations?
