Your PM box is full again.
The black seat goes on the bottom. The nipple on the air bag pokes through the center hole, and the hose runs out the bottom of the spring perch. Nothing goes on the top.
I ran the hose up to the emergency brake cable housing, and attached it with a nylon tie, then left a loop and ran it through a hole in the inner fender, and up to the thin ledge between the spare tire and the hatch well. I drilled a hole there to mount the inflator valve.
You can see the hose in this picture:
Always keep at least 5psi in the bag. Run maybe 12-20psi at the track. Do not inflate to more than 30psi.
Good luck!
Good luck!
Oh well!
