low temp switch
  • low temp switch
    whats the best low temp fan switch and thermostat for a 93 fourmla?
    mirror burn out movie top ten burn outs
    FYI I saw this post the first time but I have no idea what you are talking about so I am not posting anything. I'm not ignoring you. As Kerm would say "peace out".
      sorry for any confusion
      i have herd that you can lower the tempture that the cooling fans cutin at as my cay runs at 220 when sat in traffic does this help in explaning what i ment
        The only ways I know to do it is with a manual switch like http://www.slponline.com/view_produc...RTNUMBER=63011
        The other is to reprogram the computer. About 100 for a cable and another 200+ for software.
        I don't know of a way to replace the sensor to fool the computer but since it just measures resistanace, I wonder if you could add a resistor inline to fool it. It might fool it to making it run hotter though. I'm not smart enough to know how it works.
          http://shbox.com/1/4th_gen_tech2.html#cooling
          http://shbox.com/1/4th_gen_tech2.html#ect
            hypertec
            i had herd that hypertec done a 160 stat and a temp sender but i have not herd good things about hypertec
              You can also make a manual fan switch for ~$10 or less in parts.
              Some relatively good instructions here, but the location of the connector in the pics may be a little different on a 1993. You can use wire taps to make the connections instead of soldering if you want.
              Another diagram here. Using LEDs that have resistors built in makes it a little easier.
                I found some 12 V LED's online that have built in resistors but it doesn't mention what the resistance it is, actually of them do. Does it matter?
