whats the best low temp fan switch and thermostat for a 93 fourmla?
low temp switch
low temp switch
mirror burn out movie top ten burn outsTags: None
FYI I saw this post the first time but I have no idea what you are talking about so I am not posting anything. I'm not ignoring you. As Kerm would say "peace out".2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
sorry for any confusion
i have herd that you can lower the tempture that the cooling fans cutin at as my cay runs at 220 when sat in traffic does this help in explaning what i menthttp://www.pontiacdriversclub.co.uk/ keeping it pontiac in the the uk. 93 formula a4 ZR1 rims
The only ways I know to do it is with a manual switch like http://www.slponline.com/view_produc...RTNUMBER=63011
The other is to reprogram the computer. About 100 for a cable and another 200+ for software.
I don't know of a way to replace the sensor to fool the computer but since it just measures resistanace, I wonder if you could add a resistor inline to fool it. It might fool it to making it run hotter though. I'm not smart enough to know how it works.2002 Electron Blue Vette, 1SC, FE3/Z51, G92 3.15 gears, 308.9 RWHP 321.7 RWTQ (before any mods), SLP headers, Z06 exhaust, MSD Ignition Wires, AC Delco Iridium Spark Plugs, 160 t-stat, lots of ECM tuning
hypertec
i had herd that hypertec done a 160 stat and a temp sender but i have not herd good things about hypertechttp://www.pontiacdriversclub.co.uk/ keeping it pontiac in the the uk. 93 formula a4 ZR1 rims
You can also make a manual fan switch for ~$10 or less in parts.
Some relatively good instructions here, but the location of the connector in the pics may be a little different on a 1993. You can use wire taps to make the connections instead of soldering if you want.
Another diagram here. Using LEDs that have resistors built in makes it a little easier.Rob B 95Z A4 Tech Page (Part numbers / locations, how to's, schematics, DTC's...) Home Page - shbox.com
Originally posted by Rob B (shoebox)
Using LEDs that have resistors built in makes it a little easier.97 Trans Am A4 more or less stock (Mods: WS6 Ram Air with Fernco & K&N, 12 disc CD changer, power antenna, SLP Fan Switch, LS1 Aluminum DS, Borla Cat back, McCord power plate, Spohn tower brace, Sirius, HID fog lights)
