This info is out of date in part numbers. The last 18 months or more...i guess..GM change the P/N database. So, the advice is to contact any reliable parts departament clerk to get the P/Ns updated. Dal Slabaugh is my option..good service and fair prices
www.vandevere.com (phone)..... lockitup@bright.net.
I have the Spohn's torque arm,relocation brackets, LCA's; the SLP SFC's too and the 1LE 32 mm front way bar 21 mm rear sway bar with Prothane polyurethane bushings & end links......happy&safer cornerings. The Koni's are expensive, Bilstein are very good, garanteed for life, but don't buy the SLP-Bilstein shocks, the HD are the best.
Prices below were quoted by Dal:
22140240 shock set 388.64 /kit...KONI SET
22140228 shocks 376.88 each ...1LE brand????
22171227 shocks 90.72 each De Carbon
22182505 shocks 59.36 each De Carbon
let me know if you need
thanks
dal
van devere pont-buick"""
Well, that's the info i have already
Hope this helps you
Doc
thanks
dal
Hope this helps you
Doc
