I have a 2001 LS1 T/A, automatic for everyday use, what would be the better gear for my ride? I do about 20 high way miles a day seven days a week! Thanks for all the input!
3.73 or 4.10
drdoom7373Tags: None
Re: 3.73 or 4.10
Auto or manual?Originally posted by drdoom7373
I have a 2001 LS1 T/A for everyday use, what would be the better gear for my ride? I do about 20 high way miles a day seven days a week! Thanks for all the input!
drdoom7373 -
fastTa -
im in the market for the same thing and i contacted a couple shops and they recommended 3.73s,with a price tag around 700 parts and labor2006 GTO Impulse Blue Metallic, Blue Leather Interior
Traded in: 1998 Z28
I agree 100%.Originally posted by Jay 02 TA ws6
Wolfman will tell you that he threw 4.10s in back and didn't see much of a decrease in gas mileage, so long as you don't drive like a lunatic.
4.10 with a manual. I wouldnt want to go higher than a 3.73 with the automatic - the overdrive isnt as nice as on the T56 in 6th gear.Originally posted by Jay 02 TA ws6
Wolfman will tell you that he threw 4.10s in back and didn't see much of a decrease in gas mileage, so long as you don't drive like a lunatic.96 WS6 Formula: Ram Air, 383 Stroker, Ported LT4 Heads and Manifold, 1.6 Crane Rollers, 58MM T.B., AS&M Headers, Borla Exhaust, Meziere Elec. H2O Pump, Canton Deep Sump Oil Pan, 100 HP OF TNT N2O!! , T56 Conversion w/ Pro 5.0 shifter, SPEC Stage 3 Clutch, Hotchkiss Subframe Conn., Lakewood Adj. Panhard Bar, Spohn Adj. LCA's, BMR Adj. T.A., Custom 12 bolt w/ 3:73's, Moser Axles, Eaton Posi, Moser Girdle
drdoom7373
Thank You all for your input, I'm going to go with the 3.73! Now I have to find a reliable shop!
drdoom7373
Hmm... if you were on the West Side of the state, I would have recommended Speed, Inc. in Schaumburg, Illinois... if you don't mind a five hour drive I still recommend them. I did a lot of looking around before I went to Chicago to get my work done... there was no specialized LS1 tuner in the Detroit area -- I was shocked. Livernois Speed is probably your best bet if you don't want to drive to Chicago, they do LS1s... but they are Mustang guys first.
There is a new LS1 tuner open in Clio (near Flint) now, but I am yet to hear a single good thing about them.Former Ride: 2002 Pontiac Trans Am WS6 - 345 rwhp, 360 rwtq... stock internally.
Ahhhh, yes... good pointOriginally posted by N20LT4Bird
ok,
but whats the difference between the 3.23 and the 3.73 or 4.10?
better launch , top speed or what?93 t/a A4 3.23s
99 Alfa Romeo 166 3.0 v6, red
97 3.8 v6 A4 camaro, hardtop
00 audi a6 4.2 40 valve v8
