I am hoping to catch some insight of some sharp guys on a particulary troublesome issue. I have checked the all of the obvious issues and I am not looking for the "did you check the u-joints?" answer.
Here it is. I have a high rpm vibration - out of the blue. I initially thought it was a drivetrain issue and even went so far as to replace all the bearings in the rear because I felt roughness in the pinion yoke. Upon further review, the vibration is not related to speed as much as rpm. I feel it in the shifter and the seat when I am at a higher speed AND higher rpm. Now, I am leaning more towards engine vibration as the car is not pulling as hard as it used to. Its not a huge power loss, but noticeable. The vibration only comes in under high speeds and high revs though. If your cruising at 75 in 6th - nothing. 75 in 4th - yes vibration. Im stumped. Could it be a valve sticking, causing an unbalanced engine situation? What else?
