I am hoping to catch some insight of some sharp guys on a particulary troublesome issue. I have checked the all of the obvious issues and I am not looking for the "did you check the u-joints?" answer.
Here it is. I have a high rpm vibration - out of the blue. I initially thought it was a drivetrain issue and even went so far as to replace all the bearings in the rear because I felt roughness in the pinion yoke. Upon further review, the vibration is not related to speed as much as rpm. I feel it in the shifter and the seat when I am at a higher speed AND higher rpm. Now, I am leaning more towards engine vibration as the car is not pulling as hard as it used to. Its not a huge power loss, but noticeable. The vibration only comes in under high speeds and high revs though. If your cruising at 75 in 6th - nothing. 75 in 4th - yes vibration. Im stumped. Could it be a valve sticking, causing an unbalanced engine situation? What else?
Are you absolutely sure that it is not an ignition related failure? The whole thing about higher rpms makes me wonder if some kind of spark scatter might be just enough to cause the instability.
, but I will check pulse width and knock retard. Does the PCM isolate the cylinder that is causing the timing retard on our cars??
