I was about to go do some laundry, so I went out to the car threw everything in and started it up. After getting past all the bumps in the parking lot, I noticed the engine wasn't running right. So I look down at the gauges, and sure enough...0 oil pressure.....I immediately killed it and checked the oil. Oil level was fine. Does this mean for sure that my oil pump is out? Also, could I have damaged anything in this process? It only ran for like 30 seconds, under 1,200 rpms the whole time. If it is the oil pump (pretty sure it is), should I just pick one up at the local AZ, or is there another that would be recommended? Thanks.
P.S. This is my daily driver so I need help ASAP.
Thanks for the help guys.
