Like Rob said, a standard volume oil pump will be more than adequate for a motor under 450 HP. A high volume oil pump does create a little more parasitic drag, but it is neglible in light of the benefits that it will produce.
Oil Pump?
	fastTa -
I've also heard with a high volume pump and a stock oil pan that you can actually end up sucking up all the oil in the pan and having it all up in the engine and nothing left in the pan for it to suck up. Its not that bad of a job just take your time and make sure you get all the surfaces very clean before putting in the new gasket.1994 Firebird Formula, M6, Fan switch, 160 thermostat, Pacesetter LT headers, Morosso CAI, TB bypass, True duals.
Yeah, I think I'm gonna get out there tomorrow and change it out myself if it's not raining. After buying a jack and some stands I was able to get a good look at the job.'95 White Z28 M6 Cold air intake with K&N air filter, air foil, flowmaster cat-back, eaton posi, motive 4.10s, aluminum driveshaft, "skip shift" eliminator, '97 Z28 chrome wheels, hypertech programmed
