remove the bolt on the tranny mount(lower), support or jack up the tranny a little, remove the 4 bolts holding in the crossmember, take it out. remove the two bolts holding teh mount to the tranny. reverse the steps to install. mine took me 18 mins from driving it in to driving it out, and i had to work a little to get it lined back up, but if i had a drift pin handy it would have saved that.
just broke a tranny mount
past rides:
1994 Z28 A4 totaled
is that a process that he would need to block the engine so it doesnt rock back into the firewall??Originally posted by azkknremove the bolt on the tranny mount(lower), support or jack up the tranny a little, remove the 4 bolts holding in the crossmember, take it out. remove the two bolts holding teh mount to the tranny. reverse the steps to install. mine took me 18 mins from driving it in to driving it out, and i had to work a little to get it lined back up, but if i had a drift pin handy it would have saved that.
no, because you would have the tranny/engine supported by a jack, you could block it i guess. but it is easier to move around to get back in place if you have a jack to lift and lower it.2000 WS6 T/A M6. Monster stage 3 clutch, flowmaster cat back, 4.10's, SLP lid, Hurst shifter.
past rides:
1994 Z28 A4 totaled
Ive been through several stock mounts, but I think of them like fuses - youre gonna break the weakest link when you stomp on it, so why not make it an easy part to swap out......and it has a lifetime warranty.
