What does the oil pressure run on an LS1 F-Body, at idle, and say 2,000rpm, fully warmed up. My Silverado with the iron block 4.8L is typically above 40psi at idle and slightly above 60psi at 2,000rpm (Mobil 1 10W-30, "standard" AC/Delco filter). Is this just something they do with the truck engines, or does the LS1 aluminum block 5.7L run at similar pressures?
Just curious.
Just curious.
