Without a major power adder on the engine, the O2 sensors are valuable. The adjustments are way more than "minor"..... detecting lean conditions and being able to add up t0 25% extra fuel, or a rich condition and being able to deuct up to 15% would definitely be more than minor. With the MAF setup (94 and up 4th Gens) the long term fuel trims are what allows the PCM to adapt to the kinds of changes you make with bolt-ons. Detecting a lean condition in closed loop, and being able to carry over the extra fuel to the power enrichment mode could well be the thing that saves the engine.
Even a well done power adder car can use the benefit of wide-band sensors, feeding an aftermarket ECU and running closed loop... again, immediate response to changing conditions. There's a photo of a 1,300HP 383 blown engine in a 4th Gen at the bottom of this post, and that car runs dual wide-bands and the MoTeC M800 in closed loop. (Too bad he sold it.... he might "want some"
I run open loop, no O2 sensors because the 300-shot of nitrous requires a bit of leaded fuel, and the sensors aren't going to like the lead. But I've got more than 40 dyno pulls to back up the tuning, and give me a reasonable amount of confidence that the engine will still be running after each pass...
. If I had the $$$$$ for the wide-band option on the MoTeC, and I didn't mind shelling out for new sensors every year, I think that would be the way I would prefer to run.
).I run open loop, no O2 sensors because the 300-shot of nitrous requires a bit of leaded fuel, and the sensors aren't going to like the lead. But I've got more than 40 dyno pulls to back up the tuning, and give me a reasonable amount of confidence that the engine will still be running after each pass...
I was just saying you can run with no o2s.
