So you do or don't want a street car? Make up your mind.
From the very beginning you have changed your definations. Maybe you don't realize it, but you have. There are some on this board that have gone insanely fast in their younger days. For example, I know enough about racing to know that I can't afford to be competitive any more. It takes a sponsor and without it, I can't afford it. Someone asks how to go fast, there are many that can tell you how to do it. The main thing is you have to figure out what you want to do. It sounds to me like all you want to do is sucker someone into thinking you have a street car and it's basically a pro stocker that weighs 3000 lbs, has lights, a horn, wipers and can be driven on the street with an illegal registration. Get real. If that's what you want, the easist way is to buy a turn key car and rig it with lights, horn and mufflers. That's simple really. however, savy racers will know what is up and you're toast before you turn the key.
The bottom line is that at your skill and knowledge level, you shouldn't be worried about running 9s. Work on 12s this season, 11s the next, then upgrade to get into the 10s and once you've discovered what it all takes to be consistant and to win, then work on going faster. Sorry it's not what you want to hear, it's reality and that's it. Doing it any other way is a waste of time, and money plus a huge waste of arguement energy. Work your way up to it instead of dreaming for a pie in the sky scenereo.
And...... it's BRAKE, not BREAK. One first way stops you from moving foreward, the second way stops you for the rest of the race.
this thread has gone the way of zero tech value and should slip gently into that goodnight.
Ditto to what Joe said
to go in)
