Brandon, the correct formula would be:
M1V1+M2V2=(M1V1)1 +(M2V2)1
The correct formula shows the final mass and vector.
Goodnight and farewell, I see your agenda and I'm ending it now.
For the rest of you guys, a semi and a Volkwagon Bug are traveling at 100 mph in opposite directions, but toward each other. The truck weighs roughly 10 times the weight of the other vehicle. The two collide head on. Both vehicles are now moving in the same direction, the Semi slowed to 99 mph, the volkswagon is now traveling 99 mph in the opposite direction.
Basically the bug becomes a thin coat of paint on the front of the Semi while the truck itself only slows 1 mph.
I can't image how you can miss a crew cab dually when it is immediatly next to you. The only damage to the truck was a scrape on the fender, her little misubishi had a caved in door, broken off mirror, little bits of broken trim everywhere.
